2008 RR trouble lights-tire pressure / coolant thermostat
phillman98
Hello,
I have a 2008 RR Westminster with 104,000 miles.
CODE: u0167 lost communication with vehicle immobilizer control module. p0128 coolant thermostat
TROUBLE LIGHT: tire pressure is illuminated, check engine is illuminated
DISPLAY: dash display says, "check tire pressure"
HISTORY: I took my car to tires plus to have a new valve put on and the yellow tire pressure light would not go off. As for the thermostat, this light usually comes on in the Winter and sometimes I loose heat but it is now Spring and I have heat but the light is still on.
NOTES: Tire pressure is fine (36lb front 40lb rear)—full size spare tire also has air. The tire shop said they were unable to figure it out but did say the that the aftermarket valve is compatible with RR.
Before I take it to a dealer any pay $500 to turn a light off I thought I would check with you guys here:)
Thank you! Paul from Minnesota
tflint2112
