2012 lr4 oil in intake no start
sammire92
nebraska
cranks but wont turn over. had oil in the intake. codes: 032d0341 p0027 p0029 p0028 p026 p0340 p061a p250c. couple hundred miles before this,it was over heating so changed out the thermostate and topped off coolant. was running fine no over heating, on interstate had to accelerate than started riding rough, loss of power, load engine noise. pulled over and from there would not start. cranks but doesn't turn over. can still turn manually. help.
Quijote
Metro Boston
A couple of things:
1) Define "overheating." These are aluminum blocks and don't withstand overheating very well. A little hot is fine, but cloud-of-steam billowing from your engine bay is bad. You could have damaged your head gasket.
2) That it was overheating and low in coolant tells me you have some form of the many ways in which these cars' cooling system can fail. I'd look into the main two: water pump and rear crossover pipe.
I wish for the best outcome but I have a bad feeling the cooling system/overheating issue may have created a bigger problem for you. I'd get it checked out by a pro.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I agree with this 100%. If you see ANY signs of it overheating, pull over, stop the engine, and let it cool down. In matter of fact, I changed something out and needed to refill my coolant one day. Drove it less than 5 mins, hit the highway and had to pull over due to overheating. I had AAA tow me back home, less than 1 mile away. With that said, I am very cautious about any vehicle with aluminum heads as they can quickly heat up and cool down. Heating up is the issue and can cause internal damage.
If you have it at home, do a compression test to make sure your getting compression on all cylinders. If you don't have compression, then you'll need to investigate deeper or have someone do it for you.
BTW... oil in the intake manifold is quite common, which sucks. You'll eventually need to walnut blast your intake valves to clean them.
gvillalongo
