275/60/18 okay for 08 LR3 ?
What's the OD on those? I run 275/65R18s with the rod-mod and still rub a little bit in extreme situations. ...but I think the Cooper Zeons commonly run are 285/60s so I think you're ok
Corinthian
best measurements I get with a metal tape mounted on LC rims, 18x8
30 3/4 diameter
10 1/2 wall to wall
9 is the actual tread
TIA
KyRover
You should not have any problems. I have been using Yokohama ATS's in this same size for the past year with no issues.
Corinthian
Thanks alot,
I was at the dealer Saturday for an oil change and the tech's thought that they will fit okay, but was also warned that some factory reps are known to play tough with people with larger tires and specially larger wheels for warranty coverage.
will give it a try for sure
Boaz
Most common off road tires people are running on these forums seems to be either the Cooper Zeon LTZ or Nitto Terra Grappler, both of which are 285/60/18. I have run both myself with no problems. Very slight rubbing under full compression (rock crawl) at the front of the rear wheel wells only. No damage though.
helge
