Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Air all the way...the ride is very nice and to replace the bags, take care of the pump..it costs $100.00 and takes 20 min. Resale value stays as well....everyone sas the ride stays the same after the conversion....but don't believe it....think about it ...air ride or springs...air to me sounds softer..... my 1.5 cents...
I Would go with springs. I understand people enjoying the air ride but I promise it is more trouble than it is worth. Compressors have a 100% failure rate. What will happen is the airbag will end up getting a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag kills the compressor and you have to parts you have to constantly keep buying. With air suspension there is never a permanent fix. I would recommend going to strutmasters.com and taking a look at the conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. And for a very affordable cost. I added the link below so you can check it out.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
