Now, what he might be saying in there is that the main battery cannot be used at all past a certain point, meaning whatever you are running off it will no longer run. That would be a good safety measure too.
I think that is the case. Main battery is protected.
___________________________________________________________________________________________________________________
Tim from Traxide asked me to post this:
Hi folks and a Merry Christmas to you all and please forgive me for not visiting this forum for a while.
I make the SC40-LR dual battery controllers and while I’m not out to spam the site, I would like to clarify a few quires posted in this thread.
The SC40-LR controller has a constant current capacity of 45 amps and a start-up current rate of 100 amps, which is heaps big enough to handle a single auxiliary battery set charging requirements.
The circuit breaker I use is made by Cole Hersee, in the USA and if you check out their web site you will get additional info on how these circuit breakers work but basically, the 30 amp circuit breaker is designed to tolerate 135% of it’s marked value for up to 30 minutes which means that the circuit breaker will be handling up to around 40 amps for 30 minutes and much higher currents for shorter periods.
This means if you have taken your auxiliary battery down to a low state, the SC40-LR will safely handle the higher current to be able to recharge the battery as quick as the battery can be recharged.
NOTE, while the D3/LR3 has a large capacity alternator, it is the state of charge of the battery that governs the amount of current the battery will pull, no matter how large the alternator is and this is why we have our controller set up the way it is and it is ideally suited to the LR auxiliary battery requirements.
If you have taken the auxiliary battery down to a VERY low state, the circuit breaker will cut in and out till the battery SoC rises and this means not only is the system protected but so is your auxiliary battery.
As to the cut-out voltage level of the SC40-LR, we originally supplied these units for D3s, set with a cut-out voltage level of 12.0v ( our standard setting ).
LRA approached us and asked could we come up with an LR specific dual battery controller as there were a number of other brands on the market that were causing incompatibility problems with the high tech set up of the D3/LR3s.
We did so and set the cut-out to the requested level of 12.3v and after they tested our modified controllers, we then started providing them to Australian D3 owners.
Within a very short time, D3 owners in Europe and the Middle East were buying our kits and as a number of members on this site have indicated, we sell into the USA as well.
Over the 4 years we have been making the LR specific controllers, we have been progressively lowering the cut-out voltage level, based on the fact that the original units supplied to D3 owners ( before the LRA modified levels were supplied ) are set at 12.0v and NONE have ever had a problem.
As to cold starts, we have supplied these kits to countries like Norway, Finland and other Baltic states and NONE have ever reported a problem starting in cold periods, relating to anything to do with the their dual battery set up.
BTW, here is a link to a long thread on this site about this subject.
http://www.landroverworld.org/forums/showthread.php?t=13204&highlight=sc40
