GSMblue
- Joined
- Sep 6, 2012
- Posts
- 128
- Reaction score
- 3
My wife tells me she took it out on Sunday for a 40mile drive. That alternator is getting changed out ASAP!
I just had my new (to me) LR3 die on a short jaunt to the Home Depot. It started and drove fine, but on the last corner into the parking lot as the motor dropped to idle the dash lit up like our Xmas tree. It seemed like every system was throwing an error on the dash display too. It stayed running (but not shifting) long enough to turn in the parking lot and park it.
It wouldn't jump start after that. It showed .5 volts when the battery was hooked to the car and 5.0 volts when the cable were pulled.
We put a fresh battery in it and it started and drove fine the 5 miles home, but after the drive and about 15 mins sitting we noticed smoke and burnt electrical smell coming from the lower part of the motor.
I think I blew a diode (or something) in the alternator and it's basically causing a battery short through it.
I ordered a new alternator from RockAuto, so hopefully that's the only problem. Sound reasonable to you guys?
Sounds about exactly what I would do. Keep us posted.
Installed the new (Desno remanufactured) alternator this evening. Considering it's a Jaguar based V8, crammed into a full frame chassis, using British ingenuity, it was a suprisingly easy job.
I made sure the battery had a full charge and she fired right up. No smoke, no fireworks, no drama. It took a few minutes for the ECU to re-learn the idle and stalled out once. Drove around the block and didn't see anything to worry about.
All seems fine now and the volt meter reads 13.5 at idle. The electronic throttle means I can't easily measure the voltage above idle.
I've never seen an alternator fail in such a way...direct short through the rectifiers...but all seems well.
