Brake controller for towing with LR3
C
cdncrew
Just have another towing question about LR3
Is there a spot to mount a "prodigy" brake controller. I looked around in dealer showroom and not sure if there would be a good spot? Also, is there a built in harness to conect to, I know that in GM, Ford, Dodge etc. there is an easily accesable harness to "plug" in to, does LR3 have the same?
Thanks
grommet
Yes, under the dash by the brake pedal. Ford style. You can find a place to mount fairly easily.
J
jcegold
grommet you said it's ford style. Does that mean a ford harness for the prodigy will work?
S
schafari
Ford 250 will not work. Use the F-150 only as Grommet said. Also, Prodigy sells the exact connector you need. I know Camping World stocks it as a regular item.
