Crazy Radio problem
lovemyrover
Everything works fine with my stock 2007 LR3 radio with the exception of reception. I get exactly 1 station that comes in with a strong crystal clear signal every other channel is nothing but static. Any ideas???
p.s. I live just outside the city so there is an abundance of stations to choose from
nwoods
I think God is telling you something....
lovemyrover
Well then God must like the oldies which I dont really mind but a little classic rock would be nice every once in awhile......
anyway where is the antenna?? i took the radio out everything looks fine there wanted to check the other end on the antenna cable but not sure where it is....
angasreid
I do know that the radio antenna on the back of the radio is a little black square plug. It kind of pops on and off.
Then actual car antenna is in the rear window. It's built into the glass, it kind of looks like a defrost line.
Want to hear my guess? Your radio settings have been set to local stations only.
Hold the "music note" button for about three to five seconds. I menu should come up. Once you get there, push the note button to scroll through the different options. You'll come to a menu that asks if you want local stations, or more broad stations. That's what you want. Whatever the "not local" option is.
Good luck, hope this helps.
lovemyrover
Thanks for the reply I tried that but the only option that gave me was to adjust the adaptive volume controls. I have tried every button combination i can think of I think I might have to bite the bullet and bring to the dealer.
.....Could a weak Battery be causing this???? Just a thought from left field
