lr3seowner
Running an LR3 with a 2 inch lift, what tire size have people run with a similar setup? Would 275/70/18's cause too much trouble?
Troy A
San Francisco, CA
If I recall correctly, the lift doesn't affect fit - this has been discussed many times on this forum and in other forums.
At 275/70R18, you'd be talking about a 33.2" tire which would not fit under the truck without serious modifications (frame horns, wheel wells, etc.). If you haven't read it already, check out:
https://troyangrignon.com/wheels-and-tires-for-the-land-rover-discovery-lr4/
avslash
The Lone Star State
That is the size I run.
Serious mods required and recommended.
Horns, heater lines, shark fins, EAS harness and probably some others I'm not remembering.
Honestly, not sure you could do it with the factory front bumper. Maybe, but i have some doubt.
lr3seowner
I have read the article - very nicely put together! - but I wasn't sure if things changed any from an LR4 to LR3 in terms of brake/caliper/bumper/etc. clearance. Thanks for the reply!
lr3seowner
Great information to have! I'm sure the finished product was well worth it.
Michael Gain
Clarksville, TN
I'm sure I went overboard, but:
- removed the frame horns
- reshaped the splash guards with a heat gun
- re-routed the rear passenger coolant lines
- cut and folded over the seam welds in the rear wheel wells
- installed the proud rhino SYA kit
What modifications, if any, did you need to make to have the 265/70-18s fit without rubbing?
navigare
Western Europe
So just FYI in case anyone else is planning to really off road their rig
Wheels get mangled in real terrain. No real way around it. It's a badge of honor.
I've run Compos in the pretty serious mountains of Kyrgizstan and Georgia (the country) and suffered very little damage as they are slightly withdrawn towards the inside.
navigare
Western Europe
I'm making some revisions to my post and updating / simplifying the embedded spreadsheet as I'm sure more people can make use of this. If any of y'all would not mind helping can we all pretty much agree on the highlighted cells here, namely that 30.5" ext dia. tires and smaller fit without rubbing AND fit under the truck, that 31-31.6" dia tires MAY have some rubbing and MAY have some tightness under the truck, and that once you cross over into the 32.1 and higher, you will definitely have rubbing and also will not be able to fit the spare under the truck? I know this has been beaten to death but I can only read 90 pages of forum posts so many times. :) Hoping to make this a permanent useful post for people.
Nice work, Troy! I have Compos + KO2s 265/65/18 now (also have a set of 265/60 Coopers) and confirm your findings. I have not removed the heat shield but I have preventively deflated the spare. And it was still a bit of work to get it there, so I assume an inflated one would be near-impossible to get in - and possibly to get out!
navigare
Western Europe
I can't but recommend Troy's article to everyone. As said elsewhere, I've run the Compos + Cooper Discoverer S/T Maxx 265/60/18 tyres over more than 30.000 km of difficult Central Asian terrain (and including asphalt so horribly potted it put any mountain track to shame) with the car very heavily loaded and have experienced no issues.
Interestingly, I do also have a vibration - in both front wheels, especially the left - but only when turning to park the car on asphalt or cement surfaces. Has anyone experienced that?
