Flat Tow Behind Motorhome
rickcfowler
we purchased a 2005 Range Rover HSE to use as a tow vehicle behind our motorhome. We verified with our local Land Rover that it is towable behind a motorhome and it is also listed in the motorhome dinghy towing guide as towable all 4 down with no modifications. Has anyone used their Range Rover as a tow vehicle behind a motorhome - if so, any issues to watch out for. I've read a posting about the battery draining if towed for extended periods of time with key in position I. Any information would be greatly appreciated. Thanks.
richpike
Unfortunately, I don't have an answer for you, but I just wanted to say that has to be a sweet setup - much better than the normal Wrangler or Grand Cherokee I see behind a motorhome. Good choice :biggrin:
-Rich
Just make sure it is in Neutral, and yes it will drain the battery if you leave the key on for a long period of time, if it were mine I would disable the shifter lock so I could put in neutral without the key (down side is you can put it in gear without the engine running.)
