Hi guys, I have a water leak around the engine block close around the heads. I have no coolant in my oil and there's no white smoke coming out of my tail pipe. The leak is on the driver side right under the manifold. Looks like its running down and dripping on the manifold. Its a small leak....I thinking it might be a freeze plug leak. I hope it is then that will mean the heads gasket might be fine. Does anyone know how many freeze plugs are on that side. And if it is a freeze plug leak can I replace it without taking out the engine. Thanks for your feed back 99 disco1 SD 127,000
