Front tow recovery hooks?
farwellbooth
Any place to bolt on some front tow hooks without modifying the front bumper? I need to crawl under and look... I did some searching here and don't see much.
What hooks and where to bolt?
Many thanks
There is a pretty sturdy tow ring under a removable cover in the center of the lower bumper, that's not good enough?
There is one behind a cover on the rear bumper, too. :smile: Both are very strong tow points and actually part of the chassis - I've been yanked and have yanked others at both ends, no problem. If you off-road, I'd recommend you remove both covers before you head out, so both recovery points are exposed and easy to reach if you ever need them.
Railey
Best bet is to buy some aftermarket recovery points..
Sent
roverman
Why's that? And where would you mount them?
The front one is not huge but adequate. I've snatched a stuck semi truck with the front last winter. The stock rear one is about the beefiest tow hook mount I've ever seen.
Railey
Nope. Neither. The factory points are more for transport so I am told. The aftermarket points are more robust and safer.
Sent
Railey
ImageUploadedByTapatalk1454821924.603392.jpgImageUploadedByTapatalk1454821943.475772.jpg
Sent
