Hello All
juhness_lr4
California
just bought my 1st Land Rover LR4 HSE and it's a used 2011. would like to find out since this model does not come with a dip stick anymore to check on if the oil needs to be change. also I don't see a dip stick for the transmission fluid as well and was wondering how I can check to see if I need to replace it. thanks
Welcome to the forum.
Engine like my Jag, While on level ground and after the engine has been turned off for at least 15 minutes. Without pressing the brake, press the start engine button. then via the turn signal stalk select the options and one will be oil level. As far as the transmission goes it would be best to go to someone and have them use the fancy machines that change the fluid. Then there is a bolt you can remember that will slightly overflow when full.
Vintage99
