Help my lr3 raises its off overnight . Please help
What would cause my lr3 to raise over night to extended mode
  • 1
    Votes: 0 0.0%
  • 2
    Votes: 0 0.0%
  • Total voters
Not sure but the first thing I'd check is the EAS calibration.
rjowenusa
Don't shoot me but are you sure the rear is raising and it's not the front dropping pitching the rear up in the air?
remember5
I agree, i know the system is designed to monitor all 4 points and drop to stay level if one bag's pressure decreases but I have never heard of a compressor kicking in with the ignition off.
Jazzy
Monterey, CA
rjowenusa brings up a good point. Might not be your issue, but just providing experience I had...A while back I was installing a hidden winch and had to disconnect my front air suspension solenoid. While trying to disconnect solenoid from bumper I accidentally triggered some air release...long story short, the solenoid began slowly leaking air and the front dropped overnight. I monitored for two nights and determined the solenoid to be the issue.
I ordered and installed the new solenoid and problem fixed. Solenoid cost about ~$160 online and install is extremely simply...I viewed RSW Solutions youtube video on suspension which shows how to drain the air suspension. LR dealership will do it for ~$450. Good luck!
Globetrotter
Australia
If both sides of rear go up then its the rear crossover valve is open same if both sides of front go down, then front crossover valve is open. Now I did read somewhere that after 6 hours system will try and self level.
Vintage99
