HELP! My radio needs a 5 diget code!!
jamo002
Hi Guys,
I bought my Discovery in 2004 but I only have 75,000 miles as I have other cars as well. I LOVE the looks and high seating position of the 04 Discovery (not the 12-13 MPG though).
I need help. After I replaced my battery, the dealer, Hennessey LR in Buckhead (Atlanta) only gives me 4 digits but the radio says,"add fifth number" on the re-activation screen. I have called the dealer 3 times and they swear thar even the LR North America website only shows 4 digits for my VIN #.
At the 30,000 mi check up years ago, Hennessey replaced the battery so somebody there must have known what to do. Is there a common fifth number, or a common first number?
:confused:
hawkster
If you have the radio with navigation, open glove box, on the left side (closer to driver) there will be a bar code sticker. If the bar code sticker has the number 123456789 the nav/radio code is the last 5 digits, 56789. I have a 2002 SE but it should be the same process.
hawkster
Were you successful? Also the 4 digits given by the dealer, as long as the radio wasn't swapped should match 4 of the 5 digits. That will confirm your looking at the correct bar code.
jamo002
Forget the 4 dealer code #'s. Patsy Cline at full volume confirmed the correct code!!!!!!!!!!!!
