Yes....that's right. Even with the key, I cannot open the door. Using the key, the driver's door seems to unlock (the lock thing on the inside of the door pops up), and the alarm seems to turn off. However, when I pull on the outside handle....it's seems locked.
Pretty sure that the mech inside the handle can be adjusted and then it will work correctly, but the trouble is that I can't get inside of the truck to make the adjustment.
I like the idea of disconnecting the battery....anyone have any ideas how to open the hood from the truck from the outside? Used to have a Linclon....had to open the hood from outside once, don't know it that can be done on a DII.
DiscoMike posted about getting power down to the starter....this is something that I can do, no problem. There is plenty of room under the truck, however....how much power, and what do I do?
Thanks for any help on this!
