o0OBillO0o
- Joined
- Dec 15, 2008
- Posts
- 69
- Reaction score
- 0
Problem 1: AUX input level is not sufficient.
Problem 2: Steering wheel controls cannot operate an iPod when using factory AUX jack.
Solution 1: Read the Manual, if you think the NAV voice is shouting at you or the alarms/alerts are too loud, you can set the volume offset individually. in other words set NAV voice/Alerts offset volume close to the MAIN or the stereo volume. That should fix some problems.
Solution 2: Still not loud enough, get a headphone amp ( google Total Airhead) that will add a good amount of gain to the AUX jack. Still gotta change/charge batteries. Still no steering wheel control..Clipping? see next
Solution 3: Blow some cash on a Factory connector to get a direct connection and steering wheel controls. It's slick, but the factory mount location is not the best. Shell out some bones for ProClip.com 's custom mounts. Search around there is also third party kits for less but..
Solution 4: The Cheapest. Use iTunes and burn 6 CD, Audio CDs, using 80 Minute CDs you get 8 hours of music. which is perfect if you use iTunes Genius playlist generator and select 100 tracks based on one song, it all should fit fine. Bonus you get the factory steering wheel control and a factory direct connection. worried about volume use the soundcheck feature in iTunes before you burn the disc. note: if you buy stuff from the iTunes Music Store, curse the leadership at Apple and DRM lawyers, you cannot use those tracks in a "MP3 CD"
Yeah I am for solution 4. But I would go with solution 3 and a Proclip mount if I had an iPod Touch or iPhone. Cost vs Benifits
Hope I help stimulate your Digital Lifestyle merging w/ your cars sound system.
