Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I've searched and asked many different ways, one more try! (I'm new to this)
I have a 2.5 petrol in a 1985 L/R 90, w/ LT77.
What would be the easiest transplant into it, if I wanted a V8.
Thanks!
Ok, The other option is either to fit the RR early model V8.
Or find the most basic Production V8 engine you can and retro fit this to your landy.
you will probably need to do some alterations to the bulkhead/also get a conversion plate to mate the engine of your choice to the gearbox.
the engine mounts will have to be move forwards/backwards to accomodate new engine.
Yes, you should be able to fit the RR 3.9 into your landy.
Have you got the complete RR?( i only ask because this will make your job easier!)
Try to get the haynes manuals for the RR and the LR that you have or will be using!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
