My Air Suspension Blues..........
chefjay
Greetings Everyone,
Does anyone know where I can find the parts to convert the front air suspension oof my 2006 LR3 to manual air. I have not quite figured out what else besides my costly air compressor has given up the ghost, but want to stop bouncing around while it is on order. I diconnected the electrical connector from rear valve block, aired up each side manually and they have held steady for 3 days now. When I did the same to the front it was down 2inches overnight and completly bottomed out in 48 hrs. I was thinking if i could put a T-fitting between the two front air bags/lines with a shrader valve then I'd be able to air them up and determine if they are leaking or the valve block is the culprit. Does anybody know the exact size connector/line I would need to complete this project?
