New to Land Rover's....Maintenance Issues on 06' LR3?!
Here it is: Deka 9A94 AGM battery
...recommendation compliments of tlt (poster on this board)
USMCLR3
IID Tool and alignment
Is that calibration automatic? That would be a nice feature....for the steering angle sensor I mean.
The steering angle sensor calibration is NOT automatic but it's a simple job with the tool, after you have completed the alignment and taken the vehicle out of Tight Tolerance.
I guess what I'm asking is if it's a simple selection on the IIDTool or if you have to make calculations and inputs?
USMCLR3
It's a simple calibration selection from the tool that requires no calculations from the user. The process is described on page 43 of the IID manual.
twoboarders
I've spent $8545.02 over the last three years. (2848.34 annually) Basically from 65K to the 105K I have on it now.
Usual stuff:
- 4 Tires and alignment
- Spark plugs
- Thermostat housing
- Lower control arm bushings
- Height sensors
- ABS module
- Starter
- Battery
- Wiper cowling
- A pillar repair kit
- Front diff vent per TSB
- Brake light switch
- Alternator
- Rear, Front and transfer case fluid
- Transfer Case Control Module
- Front and rear brakes
- Oil Changes
Will be completing the transmission filter next month for the tune of $800 dollars
whathaway
Doing my 2nd transmission service soon, 180K. This time with the metal pan with separate filter conversion kit. Britpart DA2142. $142 + $32 shipping. ZF fluid - $161. Labor less than 2 hours, even shorter after conversion. Subsequent service requires only the filter $23 and fluids.
No lifting the engine/transmission or disconnecting the exhaust.
I would do that in a second if it didn't reduce the oil capacity by a quart or so....because of that I'm conflicted. Either route has pros/cons.
johnsoax
I've had my 2006 LR3 SE for just over 3 years. I've put 41,030 miles on it. Currently have 127050.
I've spent $6100 on it in expenses (Including oil and oil/air filter changes). I have done most of the work myself.
Major items
Spark Plug replacement - $90
Offroad center console control cluster - $275
Replaced lower front control arms and bushings - $1600 (by dealer)
Battery replacement - $200
Rear brake replacement pads and rotors - $120
Front brake replacement pads and rotors - $150
Front air valve pack replacement (wasn't actually needed, had bad wire) - $175
Coolant Expansion tank - $150
Rear differential oil change - $10
Front Differential oil change x2 - $20
Headlamp lamp replacement - $100
Transfer case fluid replacement - $50
Transmission fluid drain and replace - $120
Front Differential vent cap replacement - $35
Tire replacement - including new tie rod ends and 5 tires - $1800 (Dealer/TireRack)
Front wheel bearings - $320
Thermostat housing replacement, and coolant, and replacing plastic T with homemade metal one - $150
Up next
Parking brake pad replacement
