OEM hitch receiver, or aftermarket?
wallyyfm
NoVA
I do leave my oem on year round but take it off every 6 months to clean it with WD40. It does start to stick and the key system isn’t the best. I do this for a bike rack. As far as capacity I have towed a toy hauler weighing 6000 lbs without issue. It hasn’t broke yet, paid 400 on eBay 5 years ago. It’s the older version - I had heard they aren’t as reliable but it’s still working.
johnnwalters
I've got an OEM that's a KNB500023 if anyone is interested buying it.
horacioad
I have one to sell.
Switched last year to a RR Sport.... long story....
Like new, two keys which were replaced not quite 3 years ago (cylinder seized)
greiswig
SW Washington
It looks like there are substantial differences between these two part numbers: KNB500023 versus LR040248. What is the effective difference? Are they both used on the same mount?
johnnwalters
I'm not 100% sure when, but at some point LR changed the receiver for the LR4. My KNB500023 fits LR3 and early LR4s. What year is your vehicle?
wallyyfm
NoVA
From what I remember the normal looking one is the upgraded newer version. The funny looking one with the under bent tongue is the older version. I actually have the older version. I was told the newer one is more reliable.
I would say get the newer one cause it probably doesn’t effect clearance issues. I have smashed mine off of rocks here and there because of the way it’s shaped. It’s never come off or dislodged but kinda of unnerving to hear it scrape.
dlonesty
Seattle
I can t say it any clearer. LRNA specifically says that tow weight will be compromised using any other hitch system on their trucks than what they have researched and tested...PERIOD. I haul a horse and I would never compromise his life to save a few bucks. You guys are playing with fire and may cause others harm.
DaytonaRS7
this is pretty standard, and 100% a legal statement by LR.
LR can only comment to what they have tested and proven worked.
The fact is, the vehicle has the ability to tow 7,700lbs. LR has designed their hitch to match.
Its up to the consumer to make sure that their aftermarket hitch has been properly tested by the hitch manufacturer, and to not exceed the lowest load rating of either the hitch or the truck (whichever is lower)
