P0366-00 Camshaft Position
Big Harold
Australia
Hi All,
I have just done the timing chains on my 2011 RR Sport. All chains, sprockets, variators and tensioners replaced now I have a
P0366-00 Camshaft position sensor B circuit range/ performance (Bank 1)
I watch the scan tool and the desired camshaft angle at idle is between -9.5 deg and +9.5 deg I am seeing 11 to 13 deg.
It only seems to do this when it is cold when hot I haven't noticed the code come back.
ernesto101
Winnipeg
Hi All,
Hi I'm new to the range rovers but had this exact thing happen to me. just wanted to know what you did to get it solved? i have a 2010 RR sport 5.0 S/C purchased with the timing slack due to worn guides issue. replaced (chains, guides, variators, tensioners, gears)car runs smooth. P0366-00is the only code that still comes up and it comes up as 2 codes....once you clear it it won't return on that drive cycle. until new drive cycle begins itll come up. I already replaced the camshaft sensor bank 1 on the exhaust side, no change. would like to know what you did if you figured it out?
Big Harold
Australia
I checked my timing again and it is correct. So I have learned to live with it. I was told that the rotor plate on the variator can sometimes be in the wrong position from the factory but I haven't pulled mine apart again to check.
I might go back in one day.
Mark
