Raw gas in cabin.
G
g ride
I sometimes can smell some raw gas in the cabin. What could that be coming from? I recently had the fuel filter changed, but I don't know if that could have anything to do with the smell....
Moose
If the fittings for the fuel filter are loose you may be leaking gasoline/petrol, and you could smell that while stopped. You should check all the fuel lines for leaks, etc. Start with the engine bay and work your way back, looking for wet spots or drips. If you come across any suspicious spots dab a little on your fingertip and smell it. If it's gasoline you'll know it.
Andy
Quadrant2
I definitely have a gas leak coming from somewhere near the rear right , just underneath the rear passenger. I've been smelling gas and just recently see drips. How do I troubleshoot? 2010 LR4.... Please help!!
