Roof Bar Seals
RizzleKicks
UK
Hey Folks,
I've been asked by my elderly neighbour , who owns a 2004 D2 and not very computer literate to put up a post on his behalf.
He has the G4 Roof Bars and has noticed the roof lining is wet, a closer inspectionconfirmed the roof bar gaskets are the issue.
Has called the local Stealers , who say the Roof Bar gaskets are obsolete and would not give out part numbers. Can anyone help auld Hamish with part numbers ?
There was also the possibility of using a sealant adhesive around the base of the bars and then setting the bars in place , what is the best adhesive to use for this and one that won't damage the paintwork , can anyone recommend sealant?
Been advised no TigerSeal as its hellish to remove if required to do so.
TIA
RizzleKicks
ajkillgore
Call Atlantic British. 1-800-533-2210. If they don't have them they can tell you where to look..
tflint2112
