Shes on the verge of stalling..
Militant-Grunt
Ive experienced this problem last year, in traffic conditions, its happening again in traffic/ on red light (sometimes) just rolling not applying gas, or when stopped and holding the brake, the rpms drop extremely low (200- 100 rpm), the engine begins to rumble and shake. The cure to this is to apply gas, I also noticed that this does not happen in neutral or in park ( most likely due to the lower load on the engine) no Idea as to what this is, I looked at the engine belt and it looks fine, but then again I dunno.
Im thinking that the fuel injectors are dirty?
Bringing her in tommorow for the fuel tank recall, after they install a new tank I will get some injector cleaner.
Any ideas as to what this may be?
D
disco1
From the symptoms you describe I would check the PCV valve as it could be getting blocked. Also you could give the throttle body a clean with a suitable carb cleaner. Lets know how you make out.
Militant-Grunt
hey disco, could you possibly take pics to show me where the valve is? How do I go about removing it?
Could also be the stepper motor is dirty....
check a few posts down from this one.... titled something like stepper location or something.... got some great pics from roverchic.... shows right where it is.
Disco2TrailEdit4
