Steering wheel shake
Jimmy Brooks
Pasadena California
Getting a noticeable steering wheel shake/jitter at higher speeds on most surfaces. Didn’t get this before upgrading to 31’s. I know the 18 inch wheels a long with the bigger tires are much heavier and track different but I’m not sure if the place that put the tires on balanced them the best or if this is just a normal thing with the bigger tires. I had my front struts as well as my LCA and sway bar bushings replaced before I put 31’s on. Anyone else get this?
Nechaken
Colorado
I had this happen after I had 265/65/18s installed.
Took it to a different shop and asked them to rebalance.
Shake 90% gone.
DaytonaRS7
i second its the tires.
There is tire balancing, and there is tire balancing. Ive had tires "balanced" before by cheap shops. wheel shook. brought it to a reputable shop, re-balanced with a road force machine and the problem was gone.
jlach993
Fresh Meadows Queens NY
I thirdly agree it’s the tires. I got cooper zeons that shook the steering wheel like a mf’er between 40-70mph. I took it to a shady shop to get them balanced and it helped a little. I figured something else was worn like the swaybar or control arm bushings. It’s not until i was washing the wheels that i noticed a weight on the tire had came off that the shady shop had put on. They were closed for the day so i went to a bmw shop and they road force balanced it. Now i have no shake at all from the steering wheel. So i’m 95% sure your tires need to be balanced.
Troy A
San Francisco, CA
I've been going through this with my 265/60R18 Cooper S/T MAXX tires so am going to look for another tire shop that does this road force balance stuff.
Toothbob
Chattanooga, TN
I’ve fought this issue with my truck as well. I would strongly recommend using the IIDtool to put the truck in alignment mode (rigid or something mode, can’t remember what it’s called) and have a really good shop do a four wheel alignment and road force balance.
