Sunroofs don’t open
Kasie Hawkins
Las Cruces, NM
Hi, just got my 2005 LR3 in May and am slowly fixing the little things. None of the three sunroofs open any ideas as to what it might be? Also looking into adding a rack that won’t interfere with them, suggestions are greatly appreciated!
Rubber Cow
Just bang on them, hard....they'll open.
The only one that should open is the one above the front seats.
bbyer
Alberta
You might provide us with an update as to your progress with the sunroofs and rack. Updates are always appreciated.
Below is a link to perhaps a hundred or so files, a few with jpg's related to a number of aspects re your 3. Some you might find of general value.
https://www.disco3.co.uk/gallery/index.php?cat=15405
Ian Morrison
Biffo 69
Birmingham, United Kingdom
The only one that should open of the three is the one above the driver front passenger seat. If this ones not working you most likely find that the sunroof module situated just behind the sunroof opening has been damaged by water leaking in from water escaping from the sunroofs water drain tubes. I’ve just replaced mine. I had a split rear water drain tube which when it rained had water splashing all over the sun roof module.
Olli Rita
Florida
I know mine was really badly stuck, but I found that if you squeeze flat crowbar under the lip of the sunroof, just above the rear side window, it pops open easily, and so does the second row also... the front sunroof is more complicated and might involve opening the hood and changing a fuse, good luck, hopefully this helps
In case you are new to the forum the above is 90% sarcasm do not use a crowbar on your sunroof.
bbyer
Alberta
I was wondering how you get 4 likes in 9 posts and have been registered for maybe 8 months.
Regardless, no crowbars - force is not required - some skill is required however.
jwest
Seattle WA
This post is clearly sarcasm but uncool.
