sway bars, do i keep them or dump them
Monty
Tom, I don't have the part number handy but they are 10" front 12" travel rear. With my setup, I'd have a hard time using all of the shock in the front but the rear with the drop cones, well the travel gets used. I will address the front travel, or lack thereof, later.
They are nice shocks and I like having the resovoirs, so I won't have to worry about shock fade.
A
antichrist
Ok, thanks. I take it you have the external resevoir then. I'll have to do some research on the implications of the different valving. Then see if I can manage to swallow the bitter pill of the cost.
Tom Rowe
Four wheel drive allows you to get stuck in
places even more inaccessible.
Monty
No problem Tom. The shocks I have do have external resovoirs, which required DII shock towers modified to allow the hose to go through the top. Any other questions just fire away.
Slam
Supporting Member
Supporting Member
Took mine off and have no problems. If you have some stiffer newer suspension than an old pair of soggy stock shocks, you probably will not notice a huge difference.
