Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a 2003 Disco SE with 78,000 miles. Dealership did a throttle body cleaning at 48,000 miles. Does anybody know the procedure for cleaning the throttle body?
Remove the air cleaner... wipe down the butterfly. Spray some carb/injector cleaner into the throttlebody... put everything back together. Add a can of seafoam (may not be what the dealer uses). Drive away. At least this is what I would do to clean the throttlebody.
Thanks for the info. I see a little dark build up at the sides of the throat where the butterfly rotates inside the throttle body. Any particular intake hose to suck the Seafoam into the cylinders?
Thanks again. I am getting code P0150 re: O2 sensor. I was told this fault code addresses the O2 sensor in front of the catalytic converter on the driver side. I purchased a front sensor from AB, installed it and had the code cleared. 9 miles the coder came back. I am beginning to think I was told the wrong side to change. Can anybody clarify if this is actually the passenger side front sensor for this code? Vehicle is 2003 Disco II SE.
Thanks
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
