GeoRover
- Joined
- Jan 4, 2012
- Posts
- 160
- Reaction score
- 1
Transmission Range Change Not Available - RESOLVED
Hello Rovers! My first post here.
Bought my first LR3 2005 SE and super excited about it. Love the vehicle and the drive except that "Transmission Range Change Not Available", "Special Programs Not Available" and such faults are hindering its true utility I bought it for. On startup I get three System Fault Errors below:
1. Transmission Range Change Not Available
2. System Fault Special Programs Not Available
3. Special Programs Off
After reading threads and learning a bit more, I went ahead and replaced the battery, bought a new Interstate MTP-49/H8. Problem persists. Also checked the passenger side fuse box (Fuse 24); it is good. Also the LOW RANGE doesn't light up either when I push it down.
Terrain Response Control Switch is not lighting up, does not even show the NORMAL drive LED - no indication of it being activated (Although it is by default). When I rotate the Terrain Response knob, it gives fault errors like "System Fault Terrain Range Not Available".
Suspension, Command Shift, HDC and just about everything else I can think of works except what I mentioned above.
I read somewhere but can't find it anymore that there was something under the driver seat that need to be replaced, like a relay or something? Usually corrodes and needs a fix/replacement. Also something about snap opening Terrain Knob area for something? Anyone know of it? That's about the last thing that I haven't been able to check or see. Want to resolve it before I take it to a shop for big dollar fix - hopefully not.
If this has been answered before, please point me to it. Thanks in advance!
UPDATE: Turns out I had bought extended warranty on the car (duh!) and the dealership that sold the car to me will take care of it. Regardless I will share the findings and fix for the rest who have similar problems. Going to shop tomorrow morning.
