water
Dave
Hi all..I have a 2002 HSE that gets water in the spare tire wheel well. There appears to be no wettness in the cabin anywhere. Any answers?..thanks
Welcome to the forum... you have a 2002 HSE what? Disco, Range Rover, or Freelander? huge difference.
Dave
Hi Joey..thanks for the welcome..my HSE is a 2002 range rover..also do you know where I can get the radio code as the radio had been removed and then returned..Thanks, Dave
Radio code if original will need to call the dealer with the vin... if no sure if original, then you will need the radio serial number, unless by some chance you have the owners manual and the code is still written on the card.
Range Rover and getting water it the spare tire holder.. sounds like the seal is leaking around the rear window... check for cuts or torn pieces.
Dave
Hi Joey..window seals seem to be ok..will check dealer for radio code..thanks again..Dave
the water has to be coming from somewhere... I do know on my 97 Disco I get moisture in the back area, but only during the winter, kind of like the freezing cold creates frost back there.. my tools are always covered in frost, this only happens in the winter.
Boye1
