http://www.lucky8llc.com/Products.asp?ProductID=3259
this kit looks slick too and keep down on faults
That's up there in price...but then new springs/shocks for my Jeep cost that much....
maybe I am misunderstanding but some of these posts reference fault messages with lift kits. is the assumption that with lift rods you are already driving around at max hieght? and changing to other modes gets another lift on top of the existing? I am just asking for clarification. I have daily driver concerns about wear on the air system. the above lucky 8 moves the air placement as a whole which appears to be a better design than rods. is that true in anyones opinion?
Normally there are 4 heights. Access, normal, off road, and extended. Extended is 4" higher than off-road and the vehicle does it automatically if it is high centered..
No, the rods do not make the suspension to drive around at max height. The rods basically "trick" the sensors and all of your heights are all increased by 2" or so. So "normal" is now 2" higher than it was, and off road is 2" higher than is used to be. The fault occurs when the vehicle tries to go into extended mode, the springs will go to maximum height but the sensors will not register that... Therefore it will be asking for 4 more inches but can't get all of it. Make sense?
Not really harmful, they only go into extended mode when they are high centered, and the driver is prompted to return the vehicle to another height once the obstacle is cleared.
Correct me if I'm wrong but I'm pretty sure with the Rod Mod, a fault occurs is when the driver attempts to access the new "Super Extended" mode (by placing their foot on the brake and manually pressing the air suspension lever to get it to raise even further) after the vehicle is already high centered and in new "Extended", i.e. old "Super Extended", and this maxes out the suspension beyond its limits and thus creates the fault
Correct me if I'm wrong but I'm pretty sure with the Rod Mod, a fault occurs when the driver attempts to access the new "Super Extended" mode (by placing their foot on the brake and manually pressing the air suspension lever to get it to raise even further) after the vehicle is already high centered and in new "Extended", i.e. old "Super Extended", and this maxes out the suspension beyond its limits and thus creates the fault
