bleizit
- Joined
- Sep 26, 2007
- Posts
- 46
- Reaction score
- 0
I'm having difficulty getting my cruise control to work and have read numerous threads on several forums. I've confirmed the steering wheel, dash and brake switches are good. The pump is operational. Actuator is good. Hoses and T have been replaced. The neutral lockout relay has not been tested, but the switch is operational in it's default setting. I cannot locate the CC diable relay anywhere in my truck. The manual I have shows it in a vehicle with steering on the right. In that case it's located on the drivers kick panel. I assume mine would be also; however, I have an open slot where I believe it should be. There are two blue and a black wire going to the white base. Check out the picture if you know these D1's and tell me what you think. Would a YWB10032 relay go there? How does the disable relay work? Can you bypass it to test the ECU? The photo is from behind the LH footwell panel.
