Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Unless you replace the whole arm assembly with the ones from a D1, you will only be able to use factory or Sill Blades.
Like many I have D1 arms and now run the new Bosch wipers which are so much better for snow , ice and downward pressure to keep you w/s clean
2 thoughts to that question, yes if you want factory blades, or Sill Blades. The other thought is that the D2 wiper arms have one spring appling pressure to the windshield, it does get weak and you get less performance from any blades at that point.
It is your cal based on how your current wipers are working.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
