Independent Service Shops
socalrovershop
it is the rear lower correct? not the the upper? there are two motors and each side that release
socalrovershop
you can check to see if the switch is working correctly remove that little cover for the switch and jump it to see if you get any signal. other than that you can try to power probe it / add your own voltage to the tail gates. email me here [email protected] and i will send you what connectors to do this with and or what to check for proper signals.
almar68
I live in Cle Elum, Washington state. Do any of you live near here and know of a good shop to take my Discovery to for service? Having electrical problems.
PanKyiv
