04 has muddy, oily feeling gunk in coolant
ToiletDuck
My 2004 has oily brown gunk in the collate. It continues to overheat. When I pop hood it has the skin colored gunk spewing out the top of the top of the cap on the coolant reservoir. I went by an autoshop to get the system flushed. They said it would be a waste of money that oil is leaking into it somewhere. I had them check the engine oil an there were no signs of water. Does the freelander have it's own oil cooler where oil could be leaking into the system?
Sounds like either a blown head gasket or a cracked head.
godspeed
blown headgasket
Joey is right about the diagnostic...
the latte coffe foam looking gunk is a combination of high pressure compression and coolant/oil mixture characteristic of a blown head gasket, craked head or cylinder sleeve failure (typical of the 6 cylinder freelander engine), there is a long shot that if the problem was the cylinder sleeves and not a head gasket that you can flush the coolant system, install a freelander cooling kit from ebay and give your freelander extended life since the sleeve probleme starts by coming and going until the sustained hig running temps completely destroy your engine..
some interesting info:
here is some info from landroverforums.com:
Hey I get a bunch of e-mails about the kit, you can get it doing a search on e-bay
"Freelander Cooling Kit" or "Land Rover Freelander Cooling Kit "
the freelander with the first prototype is running awesome and just passed 140k miles!
also other benefits is the oil stays crystal clear between oil changes and it does not lose it's viscosity due to the high running temps.
here is the info from ebay
If you have a Land Rover Freelander you know about the common engine failure, usually between 50k - 90k miles, these vehicles are nice but will not forgive you when the engine overheats, it will self destroy. the engine is was designed with different metal/steel alloys that when they overheat the expand at a very different rate and engine fails.
The entire system works great but borderline hot, so any small problems with the cooling system will be lethal, the common reason is a cracked coolant reservoir, or hose rupture, again the reservoir will crack or the hoses will fail because the engine just runs a little hotter that it should, the coolant components will crack or blow due to the excessive pressure and sustained high temperature, if you look at the temp needle, it likes to be close to the middle.
So if you have a Freelander or will buy one, do yourself a favor and buy a "Freelander Engine Cooling Kit" which is a set of relays, wires and connectors that installs in minutes and reduces the operating temperature by turning the fan (s) at a different temperatures than the programmed by factory without interfering with the a/c and other components.
This is the cheapest insurance, it will help you avoid a 5,000.00 bill replacing a freelander engine.
This is a device that prevents damage, it will not fix the damage if it already ocurred, (however it will help in cases where the damage is mild)
As all electrical components, there are no refunds, only replacement if defective. all kits are tested before shipping to insure reliability
Important: even if device fails, the factory system still works as originally described
KIT INCLUDES: DEVICE AND INSTALLATION INSTRUCTIONS
lowwill
That cooling systems kit seems suspect. Half the people on these forums either never heard of it or just laughed at the idea. If it was cheaper maybe I'll try it. As for oil in the res tank I heard that oil cooler lines do leak oil into there. If you have a warrenty bring to the indy shop/dealer for clarifacation. Good luck
