3rd Party Warranty over Internet???
importlvr1883
So I was thinking about buying a 3rd party warranty over the internet through AAAutowarranty.com. They gave me a quote for $2000 for 3yrs/unlimited miles for my 01 Disco with 98k on it. I figure it will have some issues over the next few years and now is as good a time as any to finallly get one. Anyone have any previous experience with any companies like this. Below are terms of the plan they are offering me. Give me some feedback please.
ENGINE & WATER PUMP: The following parts of gasoline and diesel engines: pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and camshaft bearings, timing chain and timing gears, intake and exhaust valves, valve springs, oil pump, push rods, rocker arms, hydraulic lifters, rocker arm shafts and water pump. The engine block and cylinder heads are covered only if damaged by a part listed above..
TRANSMISSION: The following parts of manual or automatic transmissions: torque converter, oil pump, governor, bands, drums, planetaries, sun gear and shell, sprag(s), shaft(s), bearings, shift rail, forks, and synchronizers.
DRIVE AXLE ASSEMBLY: Drive shaft, ring & pinion gears, pinion bearings, side carrier bearings, carrier assembly, axle & axle bearings, universal & CV joints except if boot is damaged or missing. Drive axle housing is covered if damaged by a broken listed covered part.
4X4 TRANSFER CASE: Internally lubricated parts of the 4x4 transfer case.
AIR CONDITIONER : Compressor, condenser, evaporator, orifice tube.
ELECTRICAL: Alternator, voltage regulator, power window motor, heater fan, and starter motor. .
SEALS & GASKETS: Seals and gaskets are replaced as part of repair or replacement of the above covered components.
CAR RENTAL & TOWING: This program provides a total of $150 for car rental and a total of $100 for towing.
LABOR & DIAGNOSTIC CHARGES : Are covered in conjunction with an authorized repair on above listed components .
TRANSFERABILITY: This program is transferable to a second owner of the vehicle or to a replacement engine and/or transmission.
Chongo
Warraties
To be quite honest with you I do not recommend or endorse third party insurance plans. The mother company may not even be in the country you reside in. And the fees of international Lawyers can be disturbing, and impossible financially to pursue. If it were me I would contact the nearest Land Rover dealership and inquire what they know that is safe and gives you the biggest service for your money. I’m sure they have all kinds of plans available, to fit your budget.
Happy Rovering………… Chongo………..
:bandit:
