A couple GAP iid tool questions....
Nelz99
NW IL
I just got the tool yesterday and was finally able to clear the airbag code, and turned off the tire pressure system for now.
1. Is it possible to use the GAP tool real time to monitor coolant temp, oil pressure and voltage while driving?
2. Is it possible to set up the digital speedo on the LR3?
Really happy to be able to dig into the system on the LR3 with this gadget!
Ruper
Chesapeake, VA
#1. I believe so, even though I have not done this yet.
#2. Yes you can calibrate the speedo, for tire/wheel options. When I got larger tires all I had to do was measure /guess OD of tire and select that size from drop down menu, then apply it, save and go.
Other features like turning on 3 blink signals, Cornering lights, additional features such as clock on the dash and flashing ECU modules.
Disco3 Drew
Missouri
Is this a tool that can be used through a mobile device or is this the bigger computer tool? I’m looking around for a good one and am up for suggestions.
If you get the Blue Tooth version you can interact with it using you phone.
