air leak?
vladyshka13
Hi folks. Two days ago I noticed that right rear suspension/shock is lower then the rest. It take about 2-3 hours to be significantly lower to notice the difference in height. When I start the car it brings it back where it's supposed to be and when I drive, I don't see the difference. Is it time to replace the air spring?
bbyer
Alberta
time to search the forums
There could be many problems. Nothing is serious right now so you have time to search thru the various forums reading all about air suspension.
Search the disco3 and Australia land rover forum as well as this one for starters.
It will take you about a month to read up and get familiar with the system; by then you will need all you have learned. The alternative is your wallet and a dealer.
Below is a place to start. There is a weeks learning just there.
http://www.**************/gallery/index.php?cat=15405
Replace the **** with disco3 co uk and insert a . in each of the two spaces.
