Aux 12V outlets switched with ignition? 2010 LR4
carversm
It seems as if some of them on the center console go off after a while but I had my XM radio plugged into them and they did not go off. Or maybe it is the one at the back of the center console that does NOT go off.
2010 LR4
Any wisdom?
Thanks
crewcabrob
I could be wrong, but the only full time powered one is the cig lighter recepticle near the driver. Which if you look in the owners manual is not to be used to power devices???
There is a delay for the other accessory charger port near the passanger in the front. I think it stays powered until you open a door after the ignition is off.
carversm
Thanks for the input. Plugged the XMradio into the passenger side outlet, left the center console open so I could see it from outside and it appeared to go off, but the next time
it seemed to stay on. Guess I'll.have to find a switched wire someplace.
Thanks
