Center Brake Light replacement
djatkinson
I've broken my Center Brake Light on my 06 LR3. I bought the replacement, but I'm not sure how to replace it. Is this a DIY or should I take it to a glass installer? :albertein
Trynian
It is a glued in place light so if you are not to comfotable with it, take in in to be professionally installed.
djatkinson
I'm not sure where to start. Any ideas about where to get that info?
Trynian
1. Disconnect the battery ground cable.
For additional information, refer to: Specifications (414-00 Charging System - General
Information, Specifications).
2. CAUTION: Always protect paintwork and glass when removing exterior components.
Remove the high mounted stoplamp.
 Carefully cut through the sealant using a glazing knife.
 Disconnect the electrical connector.
 Disconnect the washer jet hose.
3. NOTE: Do not disassemble further if the component is removed for access only.
Remove the washer jet.
1. Install the washer jet.
2. Carefully remove the sealant from the body to leave a smooth surface.
3. Install the high mounted stoplamp.
 Check for correct alignment.
4. Remove the high mounted stoplamp.
5. Apply etch primer to any bare metal.
6. Apply primer over the etch primer.
7. Apply activator to the high mounted stoplamp.
8. Fit a pre-cut nozzle to the sealer cartridge, remove the lid, shake out the crystals and fit the
cartridge to the applicator gun.
9. Apply an 8.0 mm ( 0.30 in ) wide continuous bead of sealant, 15.0 mm ( 0.60 in ) in, from the
outer edge of the high mounted stoplamp as shown.
10. Install the high mounted stoplamp.
 Connect the washer jet hose.
 Connect and secure the electrical connector.
11. Connect the battery ground cable.
djatkinson
Trynian,
Thanks for the prompt response!
This certainly looks like there is more to it than meets the eye!
I saw the reference to: Specifications (414-00 Charging System - General
I'm thinking that this is from a shop manual. How would I get one of those? If I can get one, would it have clear illustrations providing step-by-step directions; i.e., materials, starting points, etc?
Your input is greatly appreciated!
Trynian
The reference to the charging system is just about how to disconnect the battery. probably can figure that out.
This is from the online landlrover site. you have to pay a subscription to access it the manual.
http://topix.landrover.jlrext.com/topix/i18n/index
There is not much in the way of illistration for this proceedure in the manual that you can't get from just looking at the light.
djatkinson
Thanks, Trynian,
I've been waiting for the 'registration' return email for about an hour. Have you been in contact with anyone that has actually done this repair?
Trynian
No I dont know anyone that did it themselves. Everyone I know that needed to replace it had it done at a shop.
jjvd21
If you can find the directions online for installation of the rear spoiler accessory they show pictures of removal of the rear center break light. I've read a few posts about people using a Dremel or grinder to get the light off/out.
Vintage99
