Differential & Transfer Box Fluid Change
callin
Houston
Coming up on 80k miles, looking to change both diffs and the transfer box fluids. Seems to me from watching videos on YT it's pretty straight forward - any tips or tricks? Bottle pumps or large syringe work well for getting the new fluids in?
Also from the D3/D4 workshop manual (for the V8) I have the following fluids specs - are these the same for SCv6?
- Transfer gearbox oil - Shell TF 0753 1.5 litres (2.64 pints)
- Front differential oil - Castrol SAF-XO 0.56 litres (1 pints)
- Rear differential oil (EL) - Castrol SAF Carbon Mod Plus 1.72 litres (3.03 pints)
callin
Houston
I do not. The manual I have does not cover the later models with the SC V6, only the 2.7, 4.0 and the 4.4. For anything I need specifically different I would go to Topix to find it
Rover Range
Texas
What's your VIN #?
I can tell you exactly what fluids are recommended
Rover Range
Texas
Open diff: Castrol SAF-XO - 75W/90 (1.32 US quarts)
Locking diff: Castrol SAF Carbon Mod Plus (1.86 US quarts)
Transfer case: Shell TF 0753 (1.5 US quarts)
Vehicle details:
  • 2 SPD TRANS CASE WITH CTL TRAC
  • 7 + 4 PIN ELEC SOCKET/HARNESS
  • 7 SEAT CONFIGURATION
  • 19 ALLOY 7-SPK
  • 255/55 R19 A/S TYRE
  • 7187 LBS USA
  • AMBIENT LIGHT BLIND
  • AMERICAN MOBILE PHONE SYSTEM
  • ATC AIR CONDITIONING
  • AUTO HEADLAMPS-FOLLOW ME HOME
  • AUTOMATIC HEADLAMP LEVELLING
  • BADGE-LR 4 SALES
  • BUMPER APERTURE -ATLAS BLADE
  • CARGO COMPARTMENT NET
  • CARPET-EBONY
  • CD HOLDER-CONSOLE
  • CIGAR LIGHTER
  • CONSOLE-WITH CLOSED BIN
  • CONTINENTAL TYRE VENDOR
  • DOME MAPLIGHT
  • DOOR TRIM PANEL PVC
  • DRIVERS SEAT ARMREST ADJUSTABL
  • ELEC FRT SEAT ADJ NON-MEMORY
  • ENGINE TORQUE-450 NEWTON METRE
  • EXT MIRROR FINISH BODY COLOUR
  • EXTERIOR DOOR HANDLE-OBERON
  • FAMILY BADGE-LANDROVER BRUNEL
  • FLOOR MATS CARPET
  • FLOORWELL LIGHTS
  • FRESH AIR HEATER
  • FRONT FOG LAMPS
  • FRONT PARKING AID
  • FRT LWR VALANCE - DARK TECHNO
  • FRT/RR TGHND GLS W/RR PRIV GLS
  • GRILLE-BRUNEL
  • H.D. RADIO AND SDARS
  • HEADLAMP POWER WASH
  • HLDF TOUCHSCREEN
  • HSE SALES BADGE
  • HTD/P-FOLD
  • I/P DSPLY LANG SRP-US/ENGLISH
  • INCONTROL APPS
  • INTERIOR MIRROR AUTO DIMMING R
  • IP CONTRAST - EBONY/EBONY
  • IP-PVC
  • KEYLESS ENTRY/PUSH BUTTON STRT
  • LICENCE INDICATOR
  • LOADSPACE MOULDINGS
  • LOCKING REAR AXLE - E DIFF
  • LUMBAR SEAT SUPT-DRIVER PWR
  • LUNAR STITCHING
  • MANUAL SPEED CONTROL
  • MERIDIAN SOUND SYS
  • MPH/KPH SPEEDOMETER-USA
  • MUTE ACTIVATION
  • NAS LITERATURE PACK
  • NAVIGATION CENTRE-COLOR NAS
  • NON LOCKING LUG NUTS
  • NORMAL TEMP ZONES
  • PADDLE SHIFT - BLACK
  • PERSONAL TELEPHONE INTEGRATION
  • PUDDLE LAMPS-FRONT/REAR
  • PWR TILT/SLIDE SUN ROOF
  • RAIN SENSOR-WINDSCREEN MOUNTED
  • REAR BENCH SEATS 1X2
  • REAR BUMPER-PLASTIC-PAINTED
  • REAR SEAT CLIMATE CONTROL
  • REAR THROW IN CARPET FLR MATS
  • REAR VIEW CAMERA
  • REVERSE PARKING AID
  • ROW GARAGE DOOR OPENER
  • RR SEAT-35/30/35 SPLIT
  • SCISSOR JACK
  • SIDE BADGES-SCV6
  • SIDE VENTS - BRUNEL
  • SMOKERS PACK
  • SOLIHULL ASSEMBLY (UK)
  • SP WHL-CONV ALLOY (DNU)
  • STARTER SYSTEM - STOP/START
  • STEERING COL MAN TILT & REACH
  • STNG WHL-LEATHER WRAPPED
  • SUNVISOR,DUAL-PASS ILLUM
  • SUSPENSION ELECTRONIC AIR
  • TETHER ANCHORAGE RESTR-STYLE 1
  • TOWBAR HITCH RECEIVER NAS
  • TOWING PACK NAS
  • TRAFFIC MESSAGE CHANNEL-TMC
  • TYRE PRESSURE SENSORS-433 MHZ
  • ULEV 2 EMISSION
  • UNLEADED FUEL CAPABILITY
  • USA
  • XENON HEADLAMPS-NAS
  • LESS A/V JACK
  • LESS AUTO HIGH BEAM ASSIST
  • LESS AUXILLARY LIGHTS
  • LESS BLIND SPOT MONITORING SYS
  • LESS CONNECTION PORTS
  • LESS CORNERING LAMPS
  • LESS DAYTIME RUNNING LAMPS
  • LESS DVD PLAYER
  • LESS DVD SCREEN
  • LESS EMISSION TANK
  • LESS ENGINE BLOCK HEATER
  • LESS FRONT SEAT HEATING
  • LESS HEADPHONES-REAR
  • LESS HEATED FRONT WINDSCREEN
  • LESS HEATED STEERING WHEELS
  • LESS HEATED WASHER JETS
  • LESS INSTANT MOBILITY SYSTEM
  • LESS INTERIOR SCANNING ALARM
  • LESS LOADSPACE COVER
  • LESS PARK HEATING
  • LESS REAR SEAT REMOTE DEVICES
  • LESS ROOF RAILS
  • LESS RSE LANGUAGE
  • LESS SECONDARY SECURITY SYSTEM
  • LESS SPECIAL EQUIPMENT PACKAGE
  • LESS SPECIAL VALUE PACKAGES
  • LESS TV RECEIVER
  • LESS WATER WADING AID
Brian525177
Portland, OR
What's your VIN #?
Hi. Could you tell me as well what fluids are recommended for mine: And how can I find it on my own?
I just bought it with 57k miles and 90 days of limited warranty from Autonation. It appears rear dif oil was never replaced, when every 5 years needed.
Rover Range
Texas
Hi. Could you tell me as well what fluids are recommended for mine: GA597312. And how can I find it on my own?
Open diff: Castrol SAF-XO - 75W/90 (.87 US quarts)
Open diff (HEV) diff: Castrol Castrol BOT 750b (1.28 US quarts)
