Greasing question
F
FunkyFresh
I found this guide online on how to grease the driveshaft and steering things underneath the discovery. I got a grease gun and some mobil 1 grease and I got a need tip adapter for the grease gun. Will I use the need tip or do I not need it? Also, is it pretty easy greasing everything or hard to do?
N
NHESS81
I dont think youll need a tip adaptor..should be standard, what is is, schraeder??? valve...just as long as the end of your grease gun hose has a round part that the grease ******* will fit into, its all good...clean off the *******, put the hose and, and inject grease until it forces the old crud out...messy job if you get grease on yourself tho, hahahahaha, things get slippery lol...but its ok, she'll love you for doin it!
F
FunkyFresh
Alright sweet... I think I still have the receipt for the needle adapter so I could just return that if I don't need it.
BCNJ
