HELP no anything!!!!
alti
2006 Lr3 125,000 miles everything was working great....... It just died everything was flashing and stopped. Replaced battery went for a test drive after it seamed to work and one block away it went out again driving with no gauges lights etc.
all suggestions welcome please.....
Cathy:confused:
cmb6s
If you just replaced the battery, make sure those cables are clamped down TIGHT on the terminals. I had a problem where my negative battery terminal was slightly too small for the cable clamp. It worked it's way loose and I had the same symptoms... all lights out and everything dead. I ended up getting it tight enough, but I had to grab the cable with a pair of vice grips and wrench the heck out of the tightening bolt.
alti
I hear a clicking noise behind the glove box like something is trying to reset.....all error lights are on.....the car will not turn over.
alti
I was also hearing a strange whine the last few days??
Cathy
roverman
Corroded negative cable to battery? I had to have mine replaced at 80,000. Might explain the clicking behind the glove box, that's where it is.
alti
Called my rover guy going in to the shop .... With lights and error messages on he thinks alternator .....I will post after I get it back.....thanks for the help.
Cathy
My alternator howled on its way out, too...
alti
It was a strange hi hum as I would accelerate. Lasted for about 1week and then I died:)
