Help with my land rover rear window
midg8290
GB
Hi all, I am adding a post for a friend of mine who has a 2002 land rover range rover 4.6 vogue 5 door. Not sure if this is posted in the right part of the forum??
When opening my rear window on the drivers side from the central controls, I can only make it go down but not up, every other window works perfectly (up and down) from the central control and by there own switch, you can however put the window up and down with its own switch on the door.
I'm mostly fix problems with French cars like Renaults so this will be a challenge for me. If it was a wire problem then it won't work at all, same as if it was the regulator and motor. My only other options is fuse, relay or switch. I don't know how many relays or fuses it suppose to have or even the locations to them???
Any help at all would really be great please!!
Sent from my moto g(6) using Tapatalk
Pfunk951
You'll want to bounce this to the Range Rover section of the forum.. But, I'm pretty sure it's the switch, maybe try some contact cleaner, then replace the switch if it doesn't help..
Mike
midg8290
GB
Mike
Bounce??? Sorry not sure how to do that.
tragic1
