Lights coming on???????
L
leifwilson
I am having a problem that is very random. While driving the 2001 Discovery the ABS, Brake, and a downhill with exclamation point light will all illuminate along with a 3 tone beep. The brakes seem to be fine after this happens and i will continue driving. When i turn the car off and then back on the lights will no longer be on. Any ideas of what this could be??????
Check to make sure that the brake fluid is full, this is a common thing that will cause this issue.
L
leifwilson
What type of brake
If i am just adding brake fluid what type is usually in there if always serviced at LR dealership? Don't want to add something that will make it worse.
type 3 or 4 is what I recommend... type 5 is for racing and will draw moisture.
3 or 4 can be mixed if not sure what is in there, but I would bet on 4.
STQAddie91
