LR3 ABS ring / half shaft removal / Wheel bearing destroyed ABS sensor ring
nadroj
My lr3 has had a terrible wheel bearing failure. It was so bad that the ABS ring sensor thing got torn up. Is there an easy way to replace the abs sensor ring? Do I have to replace the whole half shaft. Could I just replace the outer CV joint? If I need to replace the whole half shaft do I need to seal protector tool? Or what is the best way to DIY replace the half shaft?
Thanks
tlt
That's a new one... I don't know the answer but keep everyone posted as you progress.
nadroj
I purchased a used half shaft. Planning on putting it on tomorrow. We shall see how it goes
