My Car Wont Moveee!!!
T
top222
SOMEONE PLEASE HELPP I WENT TO DRIVE MY CAR TODAY IT ROLLED DOWN THE HILL AND WHEN I TRIED TO MOVE IT WOUlDNT MOVE!!!! I need Help my suspension is bad could that be the reason? No gear will shift
More info... year, and maintenance history you can provide, any recent issues.
No a suspension issue will not cause it not to move, it may cause it not to drive correctly. (i.e. limp mode)
pascaltissot
If it is a P38 the most common problem is a bad connection in you gear box electronic system under you driver seat (left hand drive ) when this happens you can change gears but everything gets creasy .. Normally it is just a mater of disconnecting the unit cleaning the connector and this is it .Keep us informed O.K. good luck.( you have to unscrew the seat to reach the protector cover then just unplug clean and reinstall the plug .)
pascaltissot
Joey is right ,no way a suspension problem can cause this .So just go for what I told you .first.O.K.
pascaltissot
just in case you dont have the instru..
Repair Procedures
SELECTOR SHAFT SEAL REPLACEMENT SRO:41.20.59
Removal
1. Place vehicle on lift and raise for access.
2. Unplug both shift control motor electrical connectors and move wiring out of the way
3. Remove two nuts and one bolt securing end bracket.
WARNING : Do not loosen three Torx(R) screws securing encoder switch to shift control motor. The switch adjustment is set from the factory and must not be changed.
Remove three bolts securing shift control motor and remove motor.
4. Use a suitable tool to remove selector shaft seal from transfer gearbox.
CAUTION : Take care to avoid damage to seal installation area when removing old seal.
INSTALLATION
1. Lightly oil selector shaft seal and install into transfer gearbox. Use a socket the same size as the seal (a 15 mm Snap-On(R) deep well can be used).
2. Set seal flush to flange surface do not pass the shaft flange.
3. Apply Right Stuff RTV to the mating surface of the shift control motor.
4. Install new shift control motor onto transfer gearbox with four bolts. Tighten to 10 Nm. (88 in. lb.).
5. Reconnect both electrical connectors.
6. Check transfer gearbox fluid level and replenish as necessary.
7. Check transfer gearbox vent line to ensure that it is clear.
TRANSFER GEARBOX ECU REPLACEMENT SRO: 41.30.01
(This revised procedure does not require seat removal)
REMOVAL
1. Adjust the front left hand seat all the way forward and raise to the highest level.
2. Obtain radio code and disconnect the battery negative lead.
3. Remove two screws securing rear floor heater air duct (Figure 5, Ref 1) and remove duct.
4. Raise carpet and insulation mat for access.
5. Remove two screws securing heater duct mounting (Figure 5, Ref 2). Remove mounting.
6. Remove left hand screw and loosen right hand screw securing TCU.
CAUTION : Ensure that the white anti-backout strip remains in the TCU harness connector.
7. Remove TCU and disconnect multi-plug.
INSTALLATION
1. Connect multi-plug. Position new TCU and secure with screws.
2. Position rear floor heater duct mounting and secure with screws.
3. Position insulation mat and carpet. Ensure seat harness is not trapped.
4. Position rear floor heater air duct. Secure with screws.
5. Connect negative battery lead.
6. Position front seat to original position.
7. Code radio, set windows and sunroof.
8. Synchronize remote.
TCU Pin Layout
Note : View is looking into TCU connector
Copyright © 2007 ALLDATA LLC
Terms
PE_in_UAE
