Need help 2004 Discovery
Southernrock
72,000 miles
I had my transmission taken off and put back on.
The shop drove it on the lift but wouldn't start to pull it off the lift when the job was done. The engine turns over but does not fire.
The shop said they replaced a battery connector.
The Manuel and Sport mode and hill decent lights are on. They are not blinking.
The shop says that the coil and fuel pump have no voltage.
we have reset the alarm by unlocking and locking the driver door 4 times
Fueses and relays check out.
There are no codes
Thanks Jesse
Why was it removed, what was done to it?
No voltage to the coil and pump usually means the crank sensor has failed or it is not plugged in.
Southernrock
They welded up a hole in the transmission. They removed the transmission and took it to another shop to get work done.
They most likely damaged or left the crank sensor unplugged.
Vincentvip
