No crank
BoyJ
Glennville
Hi. I hope im on the right place. Im have a L3 2006 SE. The thing was flooded because of the sunroof drain pipes. I took out the seats, carpets and shifter assembly to get it dry. Removed fusebox to repair drain pipe. Put the fusebox and shifter back. The car started before I did all of that. I installed new battery also. Now I can not get the engine to crank. The dashboard comes on and I can hear the relays click. But nothing els when turning the key. If I "jump" it at he starter relay it turns over. Im have checked everything and im at a point of starting to drinking before sunrise. Can someone please tell me *** is up with this car.
Rover Range
Texas
Double check the connectors on the fuse box.
I would disconnect and reconnect all the connectors.
